Oliver 60 parts
Working on getting my 1941 Row Crop 60 back up and running. Looking for front wheel seals ( or dust shields, whichever they used.) Tried Korves, no luck. Are these available anywhere?
Also if anyone has a picture of the dash, I am trying to figure out what spot and what the ignition switch looks like.
Corey
Corey, they used felt seals which are no longer available. You will have to make the seals if you think that you need them.
You can get the felt seals from Steiner Tractor #ABC270 I used them when restoring my 1948 "70" hope this helps
Bill
Thanks for the pictures. Choke lower left, ignition switch right side inside, and lights outside right, correct?
I will check out Steiner for parts, I deal mostly with Korves if I can.
Corey
