Oliver 77 industsial
Looking at a Oliver 77 industrial and was wondering how fast the road gear is in it.Do all the gear speeds match close to the 77 standard?
   77 Standard has 3.44:1 pinion to ring gear ratio.   77 Industrial has 4.16:1 ratio.
At rated engine speed travel speeds are:
Industrial 1200x24" tire
5th 10.11 MPH
6th 17.60 MPH.
Standard 13.6 x 26" tire
5th 7.10 MPH
6th 12.37 MPH.   There are only two gears in the transmission that are different, however to install them it requires a complete teardown of the tractor (they are on the pinion shaft).
   I assume that you are looking for something for tractor rides, Take the rear end off of a Row Crop, then marry the Industrial rear end to the front frame of the Row Crop, install the axle/housing from the Row Crop and the 38" rear rubber and you have a 22 /23 MPH ride @ rated engine RPM.
   I have a 77 Standard (higher speed ring and pinion) with the Industrial gears, 16.9x26' tires and a 1650 engine, hang onto your hat, it's 30 MPH on my GPS Garmin all day long, hills do not bother it!   I installed all new tie rod ends and all new crosses in the steering joints.
Thanks BA. That is the info I needed.Thinking of taking the industrial on a tractor ride and was wondering if I could keep up with a 12-15 mph pace.Thanks again for the info
(quoted from post at 15:28:32 08/17/17) Looking at a Oliver 77 industrial and was wondering how fast the road gear is in it.Do all the gear speeds match close to the 77 standard?
Just my opinion but please don't tear apart a 77 industrial to make a race tractor they are a pretty rare piece I'll rescue it and trade you a 17 mph standard for it !!!
