Oliver 77 mis-firing
Hi folks, I've got an early model 77 (s/n 271721C77E) that I'm rebuilding with the intention of selling.
So far I've replaced the coil, points, rotor, cap, and plug wires. I'll replace the plugs, just haven't got to it yet.
The problem is the back half of the engine does nothing. (Cylinders 6,5,& 4)
The valves don't appear to be stuck, but might be a bit close (around .006 rocker clearance )
I'm sorta leaning towards either the valves need reseating, or the head gasket is toast.
Has anyone dealt with a similar problem? What sort of solution would you suggest?
Thanks,
Nick.
