Oliver 88/cummins engine
Dieseldoctor
Hello,
I am looking to build a tractor to take to tractor pulls and play with. I want to put a 6b cummins in an oliver 88. The problem is I'm a farmall guy and don't know alot about the different models as far as compatibility. I was going to use a farmall M, but I think there is more room for the engine in an oliver. I know people have done it with 1850's, but I don't know if the pieces would be the same. Any help would be greatly appreciated.
The 1850 DIESEL had a much larger area to install the Cummins because they used a Perkins engine instead of almost all the other Olivers that use Waukesha engines like the 88 did.
You will be grinding a lot of metal to make it fit, or making a custom 'tub'.
A 88 rear end will not take it. the first thing to go will be the rear bearing support for the imput shaft. a long list of other failures can follow. gear teeth, counterhaft, differential carrier, bull gears, ect.
If the weight class works, go with a 1650. If nothing else use the 1650 rear end. It bolts right to a 88 frame. A cummins fits in a 1650 frame alot easier than a 88.
