Oliver 88 rear end
2 stroke
Will the rear from a oliver 77 bolt up to a oliver 88 frame? Will the shaft coupling be the same, and will the pto shaft go in the fly wheel properly? The spider gears are shot in the oliver 88 rear I mean shot.
What about the input shaft, and hydraulic drive shaft will everything from the 77 go into the 88 flywheel and bell housing?
You will need a pto shaft from a 77. The 77 rear end housing is a bit shorter than the 88. Everything else will go right together.
The 80 if an early one has a 3 speed transmission most will be a 4 speed forward . The 88 rowcrop is a 6 speed forward transmission. They are not close to having the same shift pattern.
I have an EOA-35 in an Adams 311 Motor Grader which I think you told me was an 80 Standard. My pattern is quit odd and I wanted to see if the 80 Standard pattern was similar.
