Oliver 88 tune-up
SIIaCanuck
Gents,
If an Oliver 88 needs a tune up (ignition tune and carb rebuild), what do you suggest?
Ignition - I put Pertronix electronic ignition in my '69 Land Rover and had really good results. The make a unit for the Delco distributers so it's a quick bolt in option (both 6V +ve and 12V -ve).
Carb - rebuild or new? Stick with OEM or go for aftermarket?
The tractor will be a working tractor for towing hay rake, running PTO auger and PTO mower. A working rebuild project.
(quoted from post at 20:56:24 08/05/13) I put a Pertronix unit in my 88. Haven"t had to
touch it in 8 years.
That's what I was hoping someone would say. I loved the one in my Land Rover, but each application is different.
What coil did you use? What plug gap are you using?
