Johngoat2002
I need some advice from you experienced people! The rod for the shifter is broken on the hydraulic unit. Is there any reason I cant remove the hydraulic unit just above the bottom plate to keep from having to pull the pto shaft? Thanks in advance!
Can be done, more of an issue putting it back. getting linkages lined up and gasket to stay in place. You could try taking the top cover off and see if you can access the broken rod from there. Not too difficult to remove the pto shaft and much easier to work on whole unit on the bench.
You read my mind! Last night I couldnt sleep so I pulled the top off of it. I had to remove the two bolts in the valve to get the linkage apart. Came right out! But like you said going back together might be an issue. I dont know how common of a problem this is, but Ill post my findings when Im done! Thanks for the support.
