Oliver 880 weight loss
Don-Ont
I want to pull in 5000 lb. class. Can someonr tell me the weight of the hydraulic unit, the pto and the cast front wheels. I think I can remove 600 lbs. by using pressed steel rear wheels. Any other suggestions for weight reduction?
Thanks. Don
Depending on what other equipment the tractor has, how much you add and what tire size you plan on running 5000 shouldn't be a problem and 4500 may be possible.
