Lots of guys say to run the chains dry. When I bought my first 1850 back in 73 from an Oliver dealer he told me to keep the chain sprayed with WD40 and they will be quieter and last longer. I use chain lube now and keep them lubed.
It's not a common double roller. There aren't any plates in the middle, just long pins and two rollers.you get that from the dealer as thats where i bought mine for the 1755. but, long as its a diamond name chain thats the best chain out there or used to be. if it says china on the chain its no use installing it. it will be loose in no time. and its just a double roller chain so if a person has a chunk of left over chain just cut it to length and use a new connector. chains are sold in bulk like 10 ft chunks in some places, and hard to find a place to sell just what u need. plus the long cotter in instead of 2 cotter pins is what is recommended. they are not fun to get that connector hooked up. your not going to be able to remove them sprockets anyhow with it together. the proper way to oil them chains is to throw them in gear oil and soak them. just spraying wd40 or something on them does nothing. u need the lube inside of the rollers. i oil all my chains no matter what they are on , from combine to anything with a chain. they even run quieter. i also spray them with chain lube. to me running a dry chain is foolish. tell me how the dirt gets inside the rollers on a spinning chain. lay the old chain on the floor beside the new chain and pull it apart and push it together and you will see the amount of wear. you might get 1/2 inch of stretch in it while the new one will have no stretch.
Yes you’re correct , was just thinking could get around buying the unit specific chain. They got a person. LolIt's not a common double roller. There aren't any plates in the middle, just long pins and two rollers.
Not -22, but in the pasture yes.How many of you have replaced a chain in the pasture where it came off at -20. Not fun.
In hay field hook to chopper and wagon.Not -22, but in the pasture yes.
