Oliver engine oil filters
RGinMN
I have an Oliver 1255 built by Fiat, and am looking for engine oil filters that will work with it. The AgCo filter number is 702370000. I believe a Fram PH8A will fit it, but I have no idea if it will work or a Purolator L30001. Can anyone tell me if these other, non AgCo filters, will work and do the job? Any recommendations for better or best filters?
You may be right. Here is the link I looked at to come up with the PH8A. Note that the Allis Chalmer 70237000 filter is on the list. That is the filter on the tractor now. Thanks.
http://www.quivira-marine.com/store/product/26665/OIL-FILTER,-Full-Flow-Lube/
The ph8a is a fram filter and their quality has gone downhill. PH8a is the same as ACpf 2 an old well used filter. There are a bunch of filters that will fit onto that base.Some have differant preasure reliefs inside, some have check valves. My 1850 has 2 on it right now.
Try the Wix filter lookup- it'll tell you what filter will fit what. They can also do some cross references.
http://www.wixfilters.com/filterlookup/index.asp
According to the website, it's a Wix 51452. After looking at what else it fits (the fram number looked familiar) it's the same filter as my 88 F150. I ussually buy a Hastings filter for it, and their number is a LF115.
Donovan from Wisconsin
