Oliver manure spreader
adunlap1104
Hey all,
I recently acquired an Oliver manure spreader model 7. This is my first Oliver implement and I need help with the hitch what is the best way to hook it up to my tractor.
Thanks
Here is a picture of the hitch.
I dont know buy I wonder if someone is missing. I have a different model and I believe something is missing on it. Maybe design to unhook from seat so you can use same tractor to load. I will see if I have a manual or pic.
Thanks. I'm also missing the rear sprocket and chain for the widespread. Do you happen to know how many teeth that sprocket has and the chain size? I have been looking online for possible replacements.
I think you may be right on missing a piece I may have to do some welding to get it to fit a draw bar. Thanks for the help
It's going to be hard to explain,and I don't have any pictures, but there should be a flat plate under what you have there,curved down so the drawbar goes between what you have and don't have. There was and maybe is on yours, a piece of strap iron curved inside the piece that yours has, to put the pin down through. I can't see if yours has the jack stand on it or not. We had a long rod that served as a pin and a hook to trip the stand. The tongue was hinged and would drop down a little when you pulled away. That long pin was used to hook the tongue and lift it up to back in to it, then to trip the latch and the stand would swing up when you pulled forward.
Looking a little harder,it looks like you have that stand. That lever looking thing in the middle of the tongue was what trips it. Dollars to donuts the spring that holds the latch is broken or missing.
