Filing straight and perpendicular to a surface is hard to teach and even then is rather crude. so a filer was a reasonable tool in the era when rocks were all hot. JimHow and in what circumstances does one use an power filer?
They set it out at the beauty salon when one of the manicurists calls in sickHow and in what circumstances does one use a power filer?
That's a really cool looking typewriter. Far sharper looking than the ubiquitous Underwood I learned on.My Grandparents had a Oliver typewriter.
One of the aircraft job shops that I worked in had a band filer. It had a flexible band with like 4" sections of steel files on it so when it ran across the face of the machine, it was like a continuous file. It was a pretty neat machine. That guy's shop had everything in it to make anything you ever wanted to make. He would just hand us a blue print and say make me 200 of these. We had to know flat pattern layout and how to make tooling and jigs and form blocks to make some of the stuff. I really got an education in that shop.neat old machine. there were band filers too ... like a band saw but with 'files' as the blade. doall made one.
i needed to make some small parts with refined internal surfaces and shapes and some filed to size parts so i cobbled together a small filing machine. sits in a corner now ... used it a few times since then.
I served my apprenticeship at a GM Fisher Body plant. Had a filing machine and band filer, used quite a bit on trim steels. This was back in the early 70s before CNC and wire EDM.One of the aircraft job shops that I worked in had a band filer. It had a flexible band with like 4" sections of steel files on it so when it ran across the face of the machine, it was like a continuous file. It was a pretty neat machine. That guy's shop had everything in it to make anything you ever wanted to make. He would just hand us a blue print and say make me 200 of these. We had to know flat pattern layout and how to make tooling and jigs and form blocks to make some of the stuff. I really got an education in that shop.
Gotta gotta watch them hankerings, sometimes they can get very expensive.Should not have read this It gave me a hankering to get one of these tools !
A good friend of mines, Dad worked there 45 or so years. Ran the same lathe all those years. He showed me where he had wore the wood floor down from walking back and forth along the lathe.This tool is on a auction at a local auction house. It's listed as a power filer and clearly has a file chucked in it. Is that indeed what it is? I associate Oliver with woodworking tools
Gotta gotta watch them hankerings, sometimes they can get very expensive.Oliver instrument built quality machines. They were located on the east side of Adrian Michigan. They relocated a number of years ago to a smaller newer building. But I don't know if they are still in business.This tool is on a auction at a local auction house. It's listed as a power filer and clearly has a file chucked in it. Is that indeed what it is? I associate Oliver with woodworking toolsView attachment 91002View attachment 91003
