Oliver S88 water pump
old
Replacing it is not as easy as one would believe it to be. 2 of the slotted head bolts that hold the fan shroud in place will not come out. I did find I can tilt the whole radiator assembly and get the pump in with the fan on it. Gasket that came with the pump isn't correct in that at the bottom center the pump is straight and the gasket has a bit of a dip in it but I figure silicone gasket maker will take care of that. Have the gasket on the block right now and waiting for the silicone to set up before I put the pump back in. eing around 90 and humid out doesn't help either plus it isn't in the shade
