Oliver super 55
LeeRoy94
Alright fellas, I'm needing more help. This
may sound like a stupid amateurs question but
I'm about at my end. I replaced the PTO
fiber disc and got it all put back
together. Now, why is it that without the
bush hog on I can get the PTO to engage but
once I get the bush hog hooked up all it wants
to do is grind, what an I doing wrong??
What is the proper procedure for this
tractor? desperately
need help!! Thank you!
I hate it when a post lays here this long and nobody responds. Only thing I can think is that the set screw in the over center mechanism wasn't tight and it pushed the clutch discs out and took the cogs off the outside of them.
Yes. I got mine all back together and that set screw wasn't tight. It took the outside right off those discs. Have you pulled the stub shaft out the back to make sure the splines are OK?
Okay I will try tightning that later tonight it has already removed the cogs off the first disc but the rest are still fine, but no I have not removed any shaft and checked splines. The old disc that I replaced were completely destroyed so I just assumed that was the problem but I will try those tonight when I get home and post and update, thank you!
