Oliver super 88 hydraulics
Olliejunkie
Where did I go wrong? I pipe into the hydraulic unit like it is on my other one. Do I need to change something inside? Do these valves care which way fluid travels? It's running a bale squeeze. Loader still works fine but squeeze does nothing. Pic wont load. I will try it as a reply.
Well I thought I figured it out. I read about the 3/8 pipe plug in the power port so I put one in but it still doesn't work. When I pull the remote handle the curl drops a little and when I drop the loader it chatters a bit. I am a little low on fluid but the loader operates so I would think the squeeze should too.
J I'm going to try the valve off another tractor that is plumbed that way. If that doesn't work I will get ahold of you. Thanks, Paul
Swapping valves worked! Must have been the wrong kind. I know little about hydraulics.
Next question. On the main unit is it ok to switch the restrictor valve from front to back position? The valves are backwards to me.
