From reading the queries and responses there arises I think, some confusion about the particular findings when folks are trying to relate the results of their 'letrical sleuthing.
There are statements like: "I followed the power through the ballast resistor and there was 6.2 volts on both ends and there was 6.2 volts at the coil so I know the current is getting there." or some similarly mixed assessment.
These types of statements can be pretty difficult to read through.
It really helps the language (and the logic) to always consider current THROUGH, power AT and voltage ACROSS any element of the circuit (though voltages taken with respect to chassis ground are typically described AT point such and such) -it is still well to keep in mind that this is the voltage ACROSS every element up to that point.
This is not hairsplitting; electrical quantities have specific names and meanings so we can pretend that it's all scientific-like.
It is genuinely helpful when you post questions (or answers for that matter) to consider the nature of the quantities you are relating to accurately convey the problem and your measurements to potential respondents.
current through
power at
voltage across (or @ a point from ground)
resistance across
fwiw,
kevin
current through
power at
resistance across
fwiw,
kevin
