On Part Number Help - Model A
dunncl66
Can one of the kind folks here help determine the correct starter mounting plate part number for an early Model A please. I was told PN A2232R would work but it is not shaped correctly to cover the case. The A2232R has a clipped corner and is different than the non-electric start A524R cover plate. Thanks for any help.
How early is "early"? For serial number range 477000-583999 the number you have is correct. (A 2232R)
Are you referring to the unstyled models?
You mention "starter mounting plate", then "non-electric start cover plate". That is a bit confusing. You probably mean the "lighting equipment only" crankcase cover which has part number A 2246R.
I currently have a 1937 Unstyled A that I would like to covert to electric start. The current A524R crankcase cover plate is shaped differently then the part I bought A2232R that I hoped would fit.
Does anyone happen to have the correct PN for the crankcase cover with the starter mount for an early A?
