Hello all,
I have just purchased a one arm loader Model # I9-276 for my 1961 Ford 861. The brackets came with it except for the strap that bolts underneath to the transmission. My problem is that all I can find are assembly and mounting instructions for the 711/722 aeries loaders. My Hip bracket looks like the one in the 711, except the holes that go into the transmission housing behind the starter are 90 degrees off. That is they bolt in from the top, and they should go in from the side. Also the bottom hole looks like it should bolt to the bolt hole that bolt the motor to the transmission, which is different than the 711 series shows. Hopefully you can see what I'm talking about in the pictures. I didn't see it on the tractor it came off of, but they said it was an 861. Is the 726 a later version of the 711? I can drill the holes through the side and make it work, but before I do that I want to make sure I'm not missing something. Anyone know of a manual for the 276 loaders?
