One ton northern tool engine stand
SVcummins
Well the parts never have showed up that didnt show up with the rest of the stand so I had a machine shop build me an engine ptate . Picked up some square tubing going to extend the rear legs about a foot on each side . Eventually going to order a 3 inch pillow block bearing and replace the junky pipe system it now has .
I never did like a stand like that. When you want to torque a bolt, it moves across the floor. I built my own with removeable 2x4's so the engine can sit solid.
I have several stands that i modified much like yours .But i poured 2 8 inch pipes
in the floor , and built stands on them,they don't wiggle or move around. Have
built some large engines on them.
george
If I build something, I head to the iron pile, and usually find what I need. I start building If I don't think its going in the right direction. I start over, or make it right. Stan
So northern tool emailed me back with a piddly offer of a 27$ rebate . I guess thats better than a poke in the A** but not much after almost 3 months
So what is going on with the torpedo heater with the cover off? I just went through two of them for a total of 197,000 btu plus another 100K with propane. Now it has warmed up and don't need them. Replaced filters, a rotor, transformer, a nozzle and adapter. Be warm next year though.
I think it just needs cleaned the fuel tank . It runs a
minute and shuts off mr little one did the same thing
it had rusty fuel in it I took it all apart cleaned it out
and it runs good now
Its actually the right height and I can sit on it 12
hours a day and not be sore when its on a horse
anyway
Its ready almost for the trial run . Dont know who to send the thank you card and cookies too but someone on here suggested using antifreeze for cutting fluid and boy does it work . An old guy I worked with at new holland taught me how to make a centered hole with a bit the size of the hole sure more accurate than a center punch
Ive seen guys hang big diesels off these stands with no modifications and it is pretty sketchy I have no plans of rolling a fully assembled engine over on this stand and I cant see any reason you would need to either
