Ed S.
- Location
- Middle Tennessee
Been taking a little bit of a breather since getting the 8N going, but did spend a little time on it last night. I got the oil line leak slowed down to a drip-drip from the gusher that it was, but suspect I munged the flaring job and will have to redo that line (from oil block on right rear to oil filter on left front).
Also bent and tapped on the fan shroud and got the "interference fit" almost corrected - at idle it doesn't hit, but under load it does. More bending and tapping is in order, I think.
My ammeter is still showing a pegged-out +30 amp charge (I did check to make sure wires are hooked up to the right terminals - when you turn the lights on, you get a discharge). While running, I turned all the lights on, and after 15 seconds or so, they all went out and won't come back on. Did not troubleshoot either of those problems yet, but suspect blown fuses are possibly related to the ammeter indication.
Other than that, she's running pretty smooth - a little hint of a miss at high RPM, but I have not yet adjusted the carb (just left it where it was when I took it apart). She's got a nice sound, especially after being used to my loaner 8N which had a blown out exhaust gasket.
Lift worked fine, a little slow and jerky coming up (no load).
Drove 'er around in 1, 2 and 3 gears, goosing the throttle, and did fine.
Oh, while driving into Princeville, IL yesterday, the fellow that has the freshly redone 601 for sale also had a fresh 9N sitting next to it. Didn't catch the price on that one, but would be happy to check or grab photos if anyone is interested.
All for now - have a great Independence Day weekend!
es
es
