Opinions on tractor please.
TJH72
I am currently looking a new used tractor. I am looking at a AGCO White 6145 or 6144. I would be using it for Hay work, Tillage, etc... Has anybody had experience with these tractors? Are they good or bad? Any weak points I should look for?
Thanks,
TJH72
The model with the 32 speed Forward and reverse transmission (6144 I believe) is the Massey transmission. Good tractor except it has a mechanical diff lock that is hyd actuated. It will not unlock when under load. If you can live with that, it would be a good tractor. The 6145 has a power shift trans and would be a good tractor as well.
