Original 8N Drawbar Clevis Assembly
Jeff E
I own a 1948 8N tractor and was wanting to restore the tractor back to original as much as I can. Does anyone know what clevis assembly came on the tractor in 1948? I have a 8N802C clevis assembly now but when I purchased an original draw bar to go in it the clevis pin hole in the draw bar is too small. I've seen an NCA803B offered on yesterday's tractor that has a different style clevis assembly with hanger to bolt on the rear around the PTO shaft, was this an original set up on the 1948 8N or was this something added in later years? Does anyone know what the original setup would have consisted of?
The 48 I have was very original when I got it, and has the 8N802C assembly. Might be that yours has an oversize pin in it to compensate for wear. Is the new drawbar hole grossly undersized or just a few thousandths? If it was me, I'd bore that drawbar out to fit the pin and use it. I don't think any 8N came from the factory the style that goes around the PTO shaft, those were started with the newer number series tractors. But I might need correction on that.
