Original style U bullet muffler
DiggerIn
I'm restoring my grandfather's 1946 UTU and am looking for original style bullet muffler. I bought a couple from a fellow in Missouri several years ago, who was remanufacturing them. I've lost his contact information. Anyone have any leads on availability anywhere? Thanks, Digger!
Little Repair; Walnut, KS; 620-354-6468; it is a good original style reproduction, good quality.
For 1946 you should have 7" flat lens lights. Reproductions are available from several sources - Steiner tractor, Korves Oliver to name a few.
(quoted from post at 17:28:34 07/05/15) Thanks so much. How about original style lights?
I'm guessing those are the 7" lights with the flat lenses. Steiner's has brand new complete units. Used ones in various states of repair can usually be found at swap meets. The vendor I mentioned above also carries all the components to refurbish used lights. Sometimes its almost as cheap to buy new ones as it is to fix up used ones, but I like the challenge on occasion.
I'm guessing those are the 7" lights with the flat lenses. There is a vendor which has brand new complete units. Apparently I can't mention the name here. (edit--It must just be the modern view which won't show the name. I see it's in classic, which I don't normally use.)
Used lights in various states of repair can usually be found at swap meets. The vendor I alluded to above also carries all the components to refurbish used lights. Sometimes its almost as cheap to buy new ones as it is to fix up used ones, but I like the challenge on occasion.
