In all the pole barn pole talk, I was back tracking a bit and like what Paul and a few others were saying about the poles.
My question is, what is the best way to bond the boards? ...I suppose a fella would have to let the boards dry good since they've been saturated with CCA.
I always figured liquid nail would be the trick but I don't know what the BEST method would be and especially with treated lumber.
So, if anyone has some experience on the subject,
Laminated posts made of 3 2x6 or 3 2x8 nailed and glued together are much better these days. I sure wouldn't use a 4x4 or 6x6 any more, the wood is so poor it twists, and any sort of pressure treating - ot the much poorer soaking you mention - doesn't get in real far. The skinnier 2x material will soak much closer to all the way through.
Then with 3 different timbers put together, any knots or warping will not be an issue.
Also, you can spend mone on the well-treated stuff that is in the ground, and use untreated stuff above ground, putting the money where it is needed.
Going to auctions and looking around at the various pole barns, see a lot of the solid poles having issues. The laminated ones don't look so bad as I see things.
--->Paul
