OT: 1998 Monte Carlo heat problems
eremoao
Can anyone tell me if there is a way to change the blend doors manually if the blend door actuator is not working? Haven't had a chance to look at it yet, but when I change the control from cold to hot I don't hear any noise. Suppose to warm up tomorrow so I will have a chance to look then, just wanted to know while I was looking if I can do it manually so the daughter can have some heat.
not an uncommon problem. more than likely a bad blend door actuator. with the engine off, key on activate the heater controls and listen for any noise. if there is none, or a constant clicking noise, its got a bad blend door actuator. not a real bad job to change. check you tube for the proceedure.
Have the problem on my Cadillac .It was under the kick plate beneath drivers feet. I did not get the part from rock auto but the you tube video did not look too hard.
