OT 2009 ram 3500
I am considering putting a flatbed on my truck. I talked to a company today and they said I would have to have the computer reprogrammed, because of the sensors on the truck. The truck is a Laramie model. But I am not aware of any sensors on the side or rear of the existing truck bed. Is this correct? He said Dodge and Chevy require the computer to be reprogrammed, because of the electronics. Just trying to get my ducks in a row. Thanks
As long as the lights remain the same load, and if there is a back up camera or proximity alarm, they remain intact, or a tailgate lock, tailgate open indicator, any of that could set a code.
You could follow the wiring harness to the lights, see if it goes any where else, follow the wires, see what they go to.
Trucks need to have the module that controls the lighting reprogrammed to play nice with the LED lights used on flat beds now. Otherwise, a load resistor has to be installed in the turn light circuits.
(quoted from post at 23:54:00 12/13/19) I am considering putting a flatbed on my truck. I talked to a company today and they said I would have to have the computer reprogrammed, because of the sensors on the truck. The truck is a Laramie model. But I am not aware of any sensors on the side or rear of the existing truck bed. Is this correct? He said Dodge and Chevy require the computer to be reprogrammed, because of the electronics. Just trying to get my ducks in a row. Thanks
When you consider what is on the back of some of the newer trucks now days It would probably be rare to find one that didn't need some programming changes;
-Taillight circuit
-Trailer wiring
-Back up cameras
-Proximity sensors
-3rd brake lights
-Additional load of the lights on headache rack of deck
-Power tailgate locks
-Security systems
2009 hard to say what or if is on your truck.
Why are you considering a flatbed?
If you want one for a dedicated purpose like a bale handler for example they are great.
Picking up a couple of skids of lick tubs they are great but for my use that is about as far as it goes.
For day to day chores I find mine to be more of a pain than it is worth because even with the short sides on mine everything on the deck must be strapped down if you want it to still be there when you get to where you are going.
Not even a spare tire will stay put unless chained down.
With a recessed gooseneck hitch you not only have to raise the trailer high enough to get off the ball but add another 6 inches or so to clear the deck when you drive out as typically the rear of the deck will sit higher when unloaded.
My sons sell and install Norstar beds. They move the backup sensors and cameras to the new bed. Some of the older Dodge need a resistor or the computer flashed to make LED lights work right. If you have more questions they would be happy to help. They have installed several hundred beds over the last few years. Tony
