OT 7.3 Powerstroke 1994
TBA
It will hiccup and keep running for a few minutes tell it gets warm then cut off like the fuel was shut off and may restart 1 or 2 times then won't start tell completely cool. I have replaced cam position sensor and checked some other stuff can't figure it out. Guess I will need it scanned. Any ideas. Thanks
Probably needs new o-rings on the injectors, they went through about 6 generations of them thru the years. Could also be bad high pressure oil pump. You do have enough oil in the crankcase.
In 94 they sold both IDI and power stroke engines, but he said he replaced the cam position sensor, which would indicate that it's a power stroke.
Rock
I have replaced the injectors glow plugs valve cover gaskets and wiring about 25k ago and fuel transfer pump. Full of oil
Burning oil, rolling coal and killing dinosaurs by the mile I understand. Now if that '94 was an early one it would be the 7.3 idi and quite possibly with the turbo option. Sounds like you have the power~stroke which runs a few minutes, warms up and dies after that is a no start condition. Cranks, just no start. The early strokes were notorious for the valve cover wiring breaking down. Rockauto might be your friend and Motorcraft is your best friend, especially with glow plugs. Everything else is notorious for having the glow plug heads swell up and removal becomes impossible without pulling the cylinder head off. The early 7.3 was mechanical injection. Later is electrical and wires breaking down when warm is a good place to start looking. When all else fails for you, oilburners.net is where you might get a wee bit better info. Just be sure to post to the Powerstroke forum and not the 6.9/7.3 Forum. Unless your looking to locate an idiT equipped machine and looking for a lead on one that is available. Maybe.
The cam sensor you replaced, was it OE or aftermarket? If you used an aftermarket, replace with OE from Ford or Navistar. I have seen aftermarket cam sensors cause misfires and stalls right off the bat. OE is so cheap, there is no point in using an aftermarket one, OE should be less than $30.
The second common failure item that causes those symptoms is the Ijection Control Module in the left front fender. There were several updates to that over the years. What codes do you have?
Just an FYI, don't go back probing injector circuits, the ICM increases the voltage to 100V to fire the injectors.
I am not a expert I own one a 95 and have had issues.
This is overlooked I always check them.
https://www.youtube.com/watch?v=3k3TWRaNPig
I am sure you could google it and get some good tips.
I would scan it because I can I have know good pids will scan them for ya if you have are can get a scanner.
Glow plus I am not sold on that they are EZ to check for me no disassembly needed. You need a high amp clamp I am going by memory total amp draw 160 bone cold as it warms up the amps go down. Are you can do each side at the glow plug relay I think its the brown wires. You will get 80 amps cold for each side. Each glow plug pulls 20 amps. 4X20 = 80, 8X20 = 160. If it has a volt meter it will read 12V for the first 60 seconds are so and gradually go up to normal charging voltage as the resistance goes up the amps go down. All in dash volt meters are not accurate mine is you could put a voltmeter on the battery. If its above 50deg you don't need glow plug I have read 30 I can tell you 50 is the cut off on mine. A few out will not cause your problem.
Dorman is a dirty word use Motorcraft parts ONLY... I also found out a dorman are any cam sensor other than Motorcraft OEM you are asking for trouble. In a jam I have used aftermarket they all bit me and it was sooner rather than later. : (
This post was edited by Hobo,NC on 01/02/2022 at 06:41 am.
(quoted from post at 05:32:36 01/02/22) It will hiccup and keep running for a few minutes tell it gets warm then cut off like the fuel was shut off and may restart 1 or 2 times then won't start tell completely cool. I have replaced cam position sensor and checked some other stuff can't figure it out. Guess I will need it scanned. Any ideas. Thanks
Typically a no start hot is a sign of a failing IPR. OEM parts only for the PSD. They just don't play well with aftermarket stuff.
AaronSEIA
Since you only replaced the IPR solenoid, pull the valve and look at the o-ring on it. It will definitely not start hot when the o-ring is blown and maybe not when cold either. Mark.
