OT 91 cad brougham speedometer
barn E
Had this car like 16 years. Odometer blinks and goes off and on. Can live with that. Now MPH goes to zero and doesn't come on sometimes for half hour. Nobody has looked at it yet. I did talk to guy whose only business is speedometers. He says pull dash and send unit(digital)out for repair. Its pc board has broken connctions. If this is like tv sets, I think I can repair. Do you think this info is correct or should I check some more? I was hoping for bad sending unit or something else. Any ideas? Please. Thanks Dave P.s. may have to wait a long time for me. I have vertigo right now and can't lay under car or dash.
In all likelyhood you just have a bad connection. Most all the vehicles since the 80s use printed circuit boards and 'ribbon' cables. All this operates and very low amperage so a marginal connection due to a little moisture, dirt or corrosion can really make things act funny and drive you absolutely crazy trying to find the problem. In the majority of the cases the problem is simply solved by unplugging the connector cable and plugging it back in to re-establish a good connection, Same goes for grounding wires and connections. Make sure the battery is dis-connected and there's no power present. I have seen thousands of dollars in new electrical parts installed in vehicles by guys trying to chase down a problem that turns out to be a marginal connection.
Just don't forget to follow Cadillac's directions to disengage the SIR system (airbags) before you poke too hard under that dash or you could have an un-pleasent surprise.
There's no harm in taking it out and looking for bad connections, if you think you can repair it yourself. You can always send it out for repair.
Good Luck and God Bless
My brother has a 95 Chevy truck. He spent $300 on parts that did not fix his intermittent speedometer problem. He found that there were 4 ground wires attached to a stud by the alternator. One of them was broke. He fixed it and the speedo works now.
SDE
