Hec In Omaha
Howdy all,
For those of you that havent following my dilema, here is brief summary.
I have a 13 gallon Air compressor that would trip my breaker every time it tried to restart after it shut itself off at the 125 psi cut out. The only way I could get the compressor to run was to bleed all the air out of the tank. Then it would run. I suspected I had a bad check valve or unloader valve. They both tested fine. Guys here on the board suggested that I had a bad Start Capacitor. BINGO! I removed the Start Capacitor and took it to my local Grainger branch and it was tested as bad. I ordered a new one $9 and installed it yesterday. Walah! The compressor runs perfectly now. One interesting observation is that the new Start Capacitor is much smaller than the old one. I had to wrap it up in foam so it wouldn't flop around in the capacitor housing. The old one was made in the USA and the new one is made in China. I hope it lasts a long time.
Thanks to all for the help with this problem I had. I hope I can return the favor someday.
Hec
Hec
