Britcheflee
Put my old international truck to bed last fall (covered with a tarp) and this spring cannot get it to fire. It was starting and running fine when I wrapped it up but now will turn over but for the life of me cannot get it to fire even with starting fluid.
Can someone answer a couple of questions for me:
I have 6 volts going into the coil - however when I check with meter on other side of coil (leading to points) I am getting a very small voltage showing - should this also be 6 volts? I am getting a voltage at the points but after removing sparkplug and holding against engine I am not seeing a spark there.
Not my week - my old Ford F100 which is usually super reliable is sputtering and misfireing - I think I may have some water in the fuel which got in the carb. This wet weather is tough on old vehicles stored outside.
Lee
Lee
