OT Buick axle nut
CWL
I will soon be working on a 2001 front wheel drive Buick Le Sabre. The boot around the driver side inboard CV joint is starting to throw grease. What size socket do I need for the axle nut? For some reason I'm thinking 36mm, but I don't know for sure. I have a shop manual for it and it looks like an easy job, but it doesn't give the socket size needed.
I think they have a boot repair kit that can be installed without removing the rotor. Check with your local auto parts store. Hal
El Toro is correct. They are called split boots and they go on easily with the wheel off and the area clean of residual grease. The best are solvent cemented together and are very long lasting. Do follow the directions carefully. I have used them on 15 joints and not had any problems. Be sure to check more than one source for the correct fit and availability. JimN
36 mm is correct if you want to replace it with oem style boot or rebuilt axle, be very careful if using the split boot or you will be doing it over
CWL,You"re on the right track.36mm socket.I wouldn"t waste my time with a split boot. Never understood why they even offer "em.The shafts come out so easily and boots are so easy to replace.
Stay away from the split boots at all cost. The trouble with them is you cannot clean out all the old grease and grit from the joint. Then you cannot pack the new grease in the joint with out getting the grease on the split in the new boot so the solvent will not fuse it properly. Also consider replacing the outer boot to while you have it apart. The outer boot does the most flexing when the wheel turns.
GO WITH AN ENTIRE AXLE! most mass merchandisers have complete axles for that car for $79 or less (autozone, carquest, etc). pulling the axle aint the issue- it's taking the old joint apart that the hassle! Back in the day when axles were still stupid expensive, we used to buy special boots made out of super flexy material- and shoot 'em OVER the joint with a contraption that looked like a cross between a caulking gun and a funnel. hardly any shops actually "shoot a boot" anymore!
