OT computer question
Chances R
A keep getting these pop up windows both at home and at work that say:
A run time error has occured do you wish to debug. Then you can click on yes or no.
This window may pop up more than once on a given page. I would like to get rid of this pop up for good, any thoughts?
As always thanks for the help.
Cheap and easy possible fix.
Pull the memory sticks out of the Mother board (while grounded to the case of the computer chassis) and re-seat them. If it still does it, try changing the memory with other correct sticks. If dtill doing it the OS may need to be reinstalled. A corrupt OS module will do that as well. If you have several programs running at the same time, and one of them is an older legacy program, try avoiding that, as memory handling may not be compatible with all old programs (as it has been fund to be faulty with humans as well as we age and try to do new things with new people) JimN
Pull down the Tools menu.
Choose Internet Options.
Click the Advanced tab.
Under "Browsing" there are two options that read "Disable script debugging".
Put checks in those two boxes.
Click Apply.
Click OK.
Restart IE.
