Thanks John. I take one little exception to your explanation. You CAN touch a bare neutral and not get shocked. Since the neutral is at ground potential there is no voltage on it. The same is true for the ground wire even if it is conducting current from a faulty unit to ground. A neutral WILL be hot however if it gets disconnected somehow from the power line ground since voltage will feed through whatever is connected to it to the neutral wire. Please don't ask me how I found that out.
I agree you can touch a bare neutral and not get shocked if its NOT carrying any current HOWEVER if its carrying current,,,,,,,,,,,,you touch it,,,,,,,,,your feet or any body part is in contact with say mother earth or any other return current path,,,,,,,,,YOU ARE PLACING YOUR BODY IN PARALELL WITH A CURRENT PATH AND CURRENT CAN FLOW IN THE AREA OF YOUR HEART AND AS LITTLE AS 0.030 AMPS CAN CAUSE FIBRILLATION
Sooooooooooooo I agree you can strip off the insulation and touch neutral and NOT get shocked,,,,,,,,,,,,
but if its carrying current and you put your body in parallel depending on what other body part is in contact with earth or another path, your body can conduct current and YOU CAN GET SHOCKED.
Thanks for the fun chat and sharing your experience, we can agree to disagree on this with all due respect, but I still believe it is possible to get shocked
by touching a bare current carrying neutral subject to what else another body part is in contact with I DO NOT RECOMMEND STRIPPING INSULATION OR TOUCHING A BARE NEUTRAL but of course no warranty !!!!!!!!
Heck Im LONG retired and may well be wrong on this and perhaps YOU CANT GET SHOCKED GRABBING A BARE NEUTRAL THATS CARRYING CURRENT but Im still afraid to try and like it being insulated myself. I just dont like the idea of my body being in parallel with a live current carrier IF IM WRONG (you cant get shocked) I WANT TO THANK IN ADVANCE ALL YOU FINE SPARKIES FOR EDUCATING ME yAYYYYYYYYYYYYYYYYYYYYYYYYYY
I figure the neutral is insulated for a darn good reason and I advise do not touch it
Best wishes David i enjoy our sparky chat even if we may disagree on this one lol
John T
