OT...Extending Buzz Box
I have a Lincoln A/C D/C buzz box in my shed and need to do some welding farther away. If I remember correctly probably wired with # 8 les than 20' from panel. Could I add a 25' extension cord to get the reach I need or is this not an option?When I look at charts it appears I would have to have a large size conductor. Opinions?
I always have used #6 for welders, but it depends how much amperage your going to use. I have a #6 extension cord for mine,
use it a lot. But, once I made some modifications to a wood stove in our basement and use the 30 amp water heater breaker,
but I was using <100 amps.
It will work just fine. Number 8ga is good for 40 amps continuous.
Chances are you won't be maxing out the welder. If you are doing some heavy welding, just stop and let the cord cool if it becomes a problem. Too hot is uncomfortable to hold.
The welders primary current is less than
secondary current. So wire on primary
side is cheaper to add.
I have a 10g 25 ft cord on my Lincoln 225
ac. It's been working that way for
years. I rarely turn it past 90 amps.
I use silo unloader cables as extension cords. They are #6 wires. I"d rather use hem when needed vs havimg long welding cables to constantly deal with.
