pat sublett
I have a 500 gallon LP tank setting on a concrete slab. Do I need to ground it?
(quoted from post at 06:00:48 11/23/17) Isn't the bare copper line running from the tank underground "ground" enough?
AaronSEIA
(quoted from post at 09:35:39 11/23/17) That is because the fumes will collect in the truck bed. With the tailgate up there is nowhere for them to go, so they accumulate and fill up the truck bed. By setting the container on the ground it allows the air to circulate around the container and the fumes to dissipate.
(quoted from post at 20:30:12 11/23/17)(quoted from post at 09:35:39 11/23/17) That is because the fumes will collect in the truck bed. With the tailgate up there is nowhere for them to go, so they accumulate and fill up the truck bed. By setting the container on the ground it allows the air to circulate around the container and the fumes to dissipate.
Well, I have never heard that explanation, but the actual reason is that the rushing liquid can create a static charge, unless the container is on the ground, because of course the vehicle tires insulate the gas container along with the vehicle. If the static charge were to discharge by a spark the vapors would of course ignite.
