OT- Need some hydraulics experts
Having some problems with a skidsteer loader, and I need some suggestions. NH LX665 skidsteer loader, sometimes it will lift the boom and hold fine. Other times it will lift slowly, and as soon as you let off the spool the boom will drop. I plumbed a gauge into the base(pressure side when lifting) of the cylinder. When lifting it will show about 1200 psi, then when I let off boom will drift down, but pressure will INCREASE at the base of the cylinder. The increase in the pressure would mean its NOT bleeding back though the valve. That tells me that the cylinder must be leaking internally? There wouldnt be any expanation for the boom going up with 1000 psi, but following while gaining pressure up to 2500 psi. Any input?
