OT - pto shaft spring
Billybuck
refurbed my Woods Rm59-3 and found the pto shaft release button spring is broken or missing. How do you get access to the spring/spring chamber?
There should be some type of little clip on the opposite end of the shaft that you press in with your finger as near as I can remember. I have had them out but it has been awhile back.
hopefully yours is the clip style. I have seen some cheap ones that they swagged / staked the metal after insertion of the push pin and spring, thus making it near impossible to take apart non destructively.
ditto on tsc having -some- spring / pin kits on the shelf.
soundguy
opposite problem - mine is pretty froze - gotta use a mallet to tap the pin in and out...
I'm planning to purty up my woods this fall, did you do a paint match? If so, do you have color codes?
thanks!
