Anonymous-0
I have a remote irrigation system solely powered by a 3 phase service. The pump is setup with 60 amp slow blow fuses and draws 36 amps running a full load. I have a need to pull a 20A 220V circuit at that location. Can I use a 277V transformer to pull the 220 single phase from 2 of the 3 phase legs or will the unabalanced load cause problems? I have tapped into one of the legs previously to run a injection pump, but am concerned about potential voltage drop with the bigger circuit. Any advice would be greatly appreciated.
Jim
Jim
