ot at the mfgrs own initiative........federal efficiency regulations drive the changes. Some tubes and ballast types will be no longer available soon.(quoted from post at 09:32:50 10/15/12) Ditto for new fixture. The light manufacturers change designs regularily to sell more light fixtures. New bulbs won't work in old fixtures and visa versa.
The game keeps changing. Ikea has announced that they will sell only LED bulbs now.
t does not appear that he gave enough information to determine whether his tubes have bi-pin (heaters) oe single pin (no heaters).(quoted from post at 12:41:06 10/15/12) Should be about 5V across the heaters on the end of the tubes. If there is not a dim red glow on the tube ends. She will never strike an arc and light.
Should be approx 230-270V open circuit end to end and drop to approx 100-140V with the lamp functioning.
The real answer is to toss the fixture , ballast and lamps them install new.
Even if operating perfect they won't strike an arc at low temps or with low line voltage.
Are you seeing anything at all from the tubes?
CWayne, you might want to keep an eye on ballast availability & stock up on a few if they begin to look like they are becoming scarce & heading toward no longer available.(quoted from post at 01:50:40 10/16/12) Why keep the old, single pin 'pieces of crap' going. Well from someone doing just that, let me offer up a few reasons. Personally I've got several boxes of bulbs that would other wise be worthless if I changed the type of light I use. Given that I've only used one and a half cases of bulbs in nearly 10 years, I've got alot of life left in not only the ones currently in the fixtures, but also in the ones left in the boxes. Second, and fortunatly mine aren't like this, but maybe they are all tied together end to end. I've seen many applications where this was done and in cases like that replacing one would be like trying to cut a link out of the middle of a chain without messing it up. For someone with say 10 of them in a row, that's what, $500 plus worth of light fixtures to replace, all over a $30 ballast. Then there are those that have been incorporated into the insulation on the ceiling, like those in my dad's shop. Taking even one down and trying to rewire it would be a royal PITA, again over a $30 ballast.
In the end there are alot of reasons someone has to keep their 'old pieces of crap' going instead of spending hundreds of dollars to replace every fixture, all over a $30 ballast. I know that in my case there would have to be a massive difference in the power bill every month for me to even begin to think about spending all that money and throwing as much away as I'd essentially be doing to make a change. That's why I do it, and I'm sure there are many others that feel the same.
