55 50 Ron
91 Ford F150 right turn signal dash indicator is out. How do I access the panel to change the bulb? According to Op Manual it's a 194 lamp and in a tough place to get at.
All the actual turn signals and 4-way flashers work normally. Thanks
Agreed. Somebody on youtube has done that on your truck model and year. Type your year into the search bar, and what you want to do.
Look up
1991 ford f150 instrument cluster removal
or 1987 to 1992
If it has a dual tank switch be careful its easy to break the switch mounts in the panel cover. I do not pull on the harness connector I take the screws out that mount the switch to the panel. The shift indicator is the same : (.
Up to 1986 All the plastic will be rotten and brittle its a ford thang. A simple bulb replacement turns into a nightmare, its like its made out of a sateen cracker. I have not had that issue as much on 87 and up.
