The '76 Chevy van 350 engine has has the fuel pump replaced, tank cleaned, and several new hoses. The fuel pressure gauge needle vibrates rapidly between 3 & 9 psi at idle. Higher rpm improves it only slightly. I can bend the guage hose back on itself to change the reading. Completely bent over and the reading is a steady 10psi. Less bend and the reading can be made to sit rock steady down to about 6psi. After that, the rapid pulses increase.
(I once had a 12 volt air compressor with a 300 psi gauge, and I changed it to a 100 psi gauge. It vibrated like crazy until I experimented with plugging the nipple with epoxy and drilling the tiniest hole thru the epoxy.)
I've used this fuel pressure gauge before on other vehicles and had steady pressure.
Is the problem with the new fuel pump? Or could it be a worn cam and/or pump rod?
The vehicle seems to run OK.
