OT WELL what happened
gitrib
Picture of impeller from Pump.
<a href="http://s323.photobucket.com/albums/nn472/gitrib/Irrigation/?action=view¤t=IMG00053.jpg" target="_blank">
IMG00053.jpg" border="0" alt="Impeller Damage
</a>
Sure looks like sand to me. It lasted 15 to 20 years and pumped a lot of water. Think if it had been a cheapy plastic impeller. Well is a gravel pack. Big hole was drilled, casing set,
filled in around with well gravel to filter water,called a gravel pack. This method is used on a lot of big irrigation wells. Replacement cost not bad if you figure it on a year to year basis.
gitrib
Did not dig that far. This pump has 22 stages. Some of them still looked ok, but the metal was worn paper thin.
