Popster MD
My 17 HP Briggs Straton twin cylinder mower is giving me fits (MTD mower). It has been peculiar to start for years. When I turn the key, the motor turns part of a revolution and seems to hang up. I release the key and then it starts normally when I try again.
The starter went bad this year (about 5 years old) and I replaced it. I also had problems with the carb. I think it may have been the fuel line deteriorating. I rebuilt the fuel pump and carb today, put on a new filter, and replaced the gas line.
As I was testing the motor after reinstalling the carb, I started it with the air cleaner off. I could see the engine do a partial revolution and then it was like a little backfire or lockup. I could see a little puff of vapor come out the carb. It then started normally an ran like new. I reassembled it, and parked it since the grass was too wet to mow.
This evening, I was in the shed and just to make myself feel good for rebuilding the beast, I decided to crank it over and hear it purr. Bad move!
Instead, it did its usual partial turn and then proceeded to scream. I think it stripped the bendix or the starter gear. Now when it turn the key it just screams.
Anyone have any ideas as to what might be causing the engine to lock/backfire?
Da**m grass is 6" tall and growing.
I presently wheeling and dealing on a Scag. Maybe the time is nearer than I think.
