You need to put a pressure gage on the fuel line and make sure the pressure is up to spec. There's a handy port to connect a gage on the fuel rail. The fitting looks like an A/C service port. If I recall correctly, you probably have the 4.9 engine with an injector at every cylinder. Double check the specs, but I think you should have somewhere around 30psi. Low pressure is probably the most common cause of a no-start. Be sure to check the filter, too.
Good Luck and God Bless
