These tractors have an amp meter , not a volt meter. U need to check with a volt meter on the battery , till then it’s anyones guess. 14.8 volts is max output u want.My Super C with a recent 12 Volt conversion suddenly started pegging to the right the original volt meter overcharging. it worked fine for the first few weeks and now overcharges. What’s wrong?
And what do I do if it’s over 14.8 volts? It’s a wire GM alternator.These tractors have an amp meter , not a volt meter. U need to check with a volt meter on the battery , till then it’s anyones guess. 14.8 volts is max output u want.
If over charging probably the alternator is bad. I had that happen on my old chev pu a while back. I had purchased previous alternator from NAPA and they replaced it. I had never had an alternator overcharge before. If you run it that way it will fry the battery. As mentioned check voltage to battery.Is my alternator shot? It’s brand new…
If it is actually an Ammeter (as the tractor left the factory with) ONE cause could be that a cell in the battery has shorted (which will make the charging system pump excessive Amps into the battery trying to bring the Volts up.My Super C with a recent 12 Volt conversion suddenly started pegging to the right the original volt meter overcharging. it worked fine for the first few weeks and now overcharges. What’s wrong?
no, we are trying to help you. follow our instructions. we cannot see it . so need some evidence like pic's as i asked. and the voltage running. plus a battery load test would be excellent also.Is my alternator shot? It’s brand new…
i meant to add the regulator would be at fault , not the alternator , not even know what u got there internal most likely or external.no, we are trying to help you. follow our instructions. we cannot see it . so need some evidence like pic's as i asked. and the voltage running. plus a battery load test would be excellent also.
You typed to fast or something? Delco “1 wire” or “3 wire”?? The problem could be different depending on which one you are using. Particularly on a 3 wire set up, failed continuity of the jumper between the #2 side spade terminal and the output post on the back could cause this.It’s a wire GM alternator.
It has an ammeter….factory. It worked fine for several months/starts and then all of a sudden it pegged the needle to the right!Not being there I can only guess soooo if it’s actually overcharging ?????? My best guesses are:
Bad battery. Try testing specific gravity in each cell and a load test
Voltage regulation circuit (or entire alternator) in the alternator is bad
A short or other wiring problem
Put an accurate dc volt meter on the battery and see what it reads initially and over long term running. Does it have an ammeter or volt meter ?
John T
You must have missed my reply question seeking clarification of your reply #4.It has an ammeter….factory. It worked fine for several months/starts and then all of a sudden it pegged the needle to the right!
I agree with hay farmer With just a single wire Delco alternator It sounds like it failed It happens with new parts.If over charging probably the alternator is bad. I had that happen on my old chev pu a while back. I had purchased previous alternator from NAPA and they replaced it. I had never had an alternator overcharge before. If you run it that way it will fry the battery. As mentioned check voltage to battery.
