Mortyouery
For some time now my 8n has spit some fluid from the radiator overflow when under heavy load. The radiator is filled properly to just over fins. Last weekend, plowing more ground than I usually take on, she began to steam after an hour or so. I let her rest for an hour, added some water, started plowing again, and fairly quickly she was blowing steam. I let her cool and drained the radiator. Nothing shocking though I think slow to drain. Refilled, went to plow, same problem. I drained again and filled with vinegar. Left for 2 days, drained, again nothing surprising came out. Pretty clean really, but I still think she drains slowly. Refilled, did a little bush hogging and soon overheating/blowing steam. I heard an infrequent "click" which might have come from the water pump. Upper hose was hot, lower not so much. There is not a lot of obvious swirling water in the radiator when you peek in. I thought I had a thermostat in her, but did not feel anything in the upper hose and there is no extra hose clamp. This only happens under heavy load.
Suggestions? I must get sunflowers planted!
