Over revving
Status
Not open for further replies.
I am thinking of buying a YM330 tractor. It is about 16yrs old but has only 427 hrs on the clock and I know it has never worked hard. After sitting for two years, after draining and putting fresh diesel in, it startrd but revs like mad and will not slow down. I have taken all the throttle linkages off and moved the arm on the injector pump manually but it still revs way too high. Has anyone got any ideas.
Above, where it says "Search this Topic," plug in "throttle" and hit "Search." It will bring up various similar accounts, and the answers.
Yes, there was no spring, and very little resistance. I am thinking that maybe it was left with the hand throttle in the fast position and as the deisel deterioated over time it is stuck in this position. How easy is it to take the pump out to clean it?
<QUOTE><s>
</e></QUOTE>
Not likely. If anything sticks it is usually the pump's plungers and they just stop pumping fuel if that happens. My guess is
1) The governor weights are stuck.
or
2) Someone tried to remove the pump before &amp; stretched the governor springs or damaged the governor linkages.
Hi. It was suggested that I towed the tractor in gear with the decompression lever open to get some oil around the governor to try and free the weights. As I had already started it twice I thought that maybe oil had already got up there and the weights would have freed themselves over the last week. I started the tractor (with my hand on the decompression lever in case it went mad again) and it ran just fine. How lucky was I?
I have been told that this problem often occurs when this engine is parked up for a long time.
Thanks for your help.
Status
