Texgasser1
- Location
- East Texas
So I found a JD 3010 propane engine, Has sat for 3 years and has water in the cylinders. I have never attempted to resurrect something like this before.
I know I need to take it completely apart, and obviously clean it. The end goal is to transform it into a standalone gas power unit.
Friend of mine joked , Once you take it apart you might as well bore and stoke it, that will make it really go.
All joking aside I have a several question, The cylinder walls are badly rusted from what I can see from the spark plug hole, [haven't removed the head yet], Should I have it bored? If so will I need a different piston ring set than stock? What exactly is stroking an engine and what does it do?
Thank You in advance.
