Overrunning Clutch
Status
Not open for further replies.
Jess-HT
I probably need to go on and get one of these because the momentum problem when using the tiller or the bush hog is a real problem. The momentum was so strong using the tiller last week till it almost pushed me over an embankment. I do have one question, however. Does the clutch change the overall amount of protrusion of the PTO Shaft?
<QUOTE author="Jess"><s>
</s>I probably need to go on and get one of these because the momentum problem when using the tiller or the bush hog is a real problem. The momentum was so strong using the tiller last week till it almost pushed me over an embankment. I do have one question, however. Does the clutch change the overall amount of protrusion of the PTO Shaft?<e>
/e></QUOTE>
Yes
Yes it adds to the length.
Be very selective with what type of overrunning clutch you buy. I learned the hard way that <s>[url=http://www.griggslawnandtra.../Heavy-Duty-PTO-Over/Detail]</s>this style<e></e>[/URL] breaks easily:
<IMG src="http://www.griggslawnandtractor.com/media/7/a20792a127c1822424b33c_m.JPG"><s>
URL]<e>
</e></IMG>
I have a box full of parts from 4 of those.
<s>[url=http://www.farmandfleet.com...-increaser-pto-adapter.html]</s>This style<e></e>[/URL] has been on my tractor for going on 3 years, not a single problem. I work my equipment frequently.
<IMG src="http://d3spdo3nk3n5ki.cloudfront.net/p300/137753-20131126062332-double-hh-overrunning-clutch-increaser-pto-adapter.jpg"><s>
URL]<e>
</e></IMG>
The top style just does not tolerate being tugged on very well. If your PTO shaft is not well lubricated or if you raise and lower the mower a lot when the mower is under a load (like mowing up and down in a ditch in heavy grass- for example) there is the potential to damage it. A very small percentage of our customers ever have problems with them but the ones that do continue to have problems- because they keep doing the same things. The bottom style is not as convenient but does tolerate abuse a little better for some reason.
Thanks Aaron - not a slight on anything Hoye sells- not even sure if you sell either or both. I lube my tiller shaft every time I put it on. The first kind came apart only with the tiller. The third time it exploded was enough. I take good care of my equipment and knew I wasn't doing anything unusual.
For me, I found the second style works best with the least headaches. It does not have the quick release like the first, but I never remove it - so that doesn't bother me. It also comes with grease fittings. YMMV. <E>:mrgreen:</E>
I have a qd OR clutch similar to the top 1 that I have been using for 12 years, although it is starting to show a little wear. It looks like the 1 Tractor Supply sells.
Status
