Paint / Rust Removal
I am undertaking the restoration of a GP. I have many parts that need rust and old paint removal. I have a media blaster that works, but it goes through a lot of media to get the big parts clean. I was wondering if I first used a chemical paint stripper and then followed up with media blasting if that would make the process quicker and use less media. Does anyone have experience doing this?
How big are your parts? A media blasting cabinet is for smaller items. For larger parts like cast housings and tinwork, you need a sandblaster setup using a sand media or Black Magic. If you're doing rusty parts you need an aggressive media and enough air to power the equipment. Chemical stripping first is a waste of time and money if you're going to sandblast anyway.
what Rochester are you from?
This might need multiple methods. For typically rusted sheet metal I wire wheel, apply rust converter,prime and paint. Once converter is applied, don't wait very long before priming or piece will begin rusting again. To put a piece in long term "holding pattern", I apply a coat of aluminum paint. For smoother finish, sand following converter,apply primer followed by filler-primer and wet sanding.
For delicate or precision parts, consider electrolysis. Long skinny part? No need for 50 gallons in large container. Dig a trench or make temporary form then line it with sheet plastic.
The paint remover made today is pretty bad. It will work but be prepared to keep applying remover for a half hour or so. Then use a power washer to clean off the residue. Dry the parts off as well as you can and set them in the sun to dry so it dries quickly. You can re-use the media from sand blasting. Where ever you are sand blasting put up tarps to contain the media in that area. Then sift the media through screen wire to remove larger particles. I cut the bottom out of a 5 gallon water cooler jugs and made a frame to hold screen wire over it inside the jug. Just set the jug on top of the sandblaster bucket and pour the sand through the strainer. It has to be shaken for the sand to pass through. I just use cheap play sand from the box stores for media but you have to sift it when new as well.
I also use play sand, sift it first with a homemade screen, catch it and reuse it. Keep it dry. I'm too cheap to pay for other media. It has it's place but is limited since it is a small unit. Most of my prep on old cars and tractors over many years has been done with my angle grinder and a course cup wire brush. Sleeves, long pants and eye protection! I find stripper frustrating and a waste of time.
You will find an air driven Needle Scaler to be one of the easiest and cleanest methods to remove rust, especially on cast parts. You can search/find ones at Harbor Frieght. Do get an extra set of needles. To hold metal from rusting back, apply a rust converter and then prime with red oxide primer. Keep in a dry, dust free environment until you have enough parts to warrant a painting session. Ace Hardware red primer is reasonably priced and does well.
I'm about 50 miles south of you and around here we have numerous Mennonites that blast for a very reasonable fee. Have used them a lot for large cast parts, cheaper than buying the media yourself and someway of using it!
You probably would have been close to me- Wallace. My gramps owned Cohocton Valley Garage, IH dealership, and Schutz Trucking and Lime Spreading
I have used numerous methods for paint removal including media blasting. I was disappointed in the media blasting because it takes much longer than expected, unless I take it to a place with a huge compressor. My compressor is a two cylinder unit. My fastest and most effective methods are the cup style twisted wire wheel and flap wheels. I use the flap wheels on flat stock only.
The local Mennonites sandblast for way less that I could ever do it myself. I pick it up immediately and spritz with phosphoric acid then epoxy primer, has worked well for me!
These, or similar other brands/sources:
For sheet metal mostly, rough cast wears them down quickly.
I stripped a 56 Dodge pickup last year. Lots of coats of paint and filler. Heat gun and scraper on thick stuff. One or two coats only these worked better than everything else. And I think I tried Everything!
I have one of those on the shelf where my wire wheels, and small grinding wheels and sandpaper live. I tried it for maybe ten minutes probably fifteen years ago.
